Pre-OC Nvidia GeForce GTX 280 and 260
Written by Harry Butler
July 19, 2008 | 09:17
Tags: #260 #280 #amp #analysis #benchmarking #benchmarks #bfg #geforce #gtx #ocx #result #review #top
Companies: #asus #games #nvidia #test #zotac
Crysis
Publisher: Electronic Arts
What can we say about this game that hasn’t been said already? Crysis was probably the most anticipated game on the PC last year and was released on November 16th 2007.
Crysis is seen by many as the poster boy for DirectX 10 and it will make your system cry, quite literally – it’s a monster! It doesn’t come as much of a surprise then, that the graphics are something special – they’re above and beyond anything we’ve ever seen in a PC game.
We tested the game using the 64-bit executable under both DirectX 9.0 and DirectX 10 with the 1.21 patch applied. We used a custom timedemo recorded from the Laws of Nature level which is more representative of gameplay than the built-in benchmark that renders things much faster than you're going to experience in game. We found that around 30-33 fps in our custom timedemo was sufficient enough to obtain a playable frame rate through the game. It's a little different to other games in that the low frame rates still appear to be quite smooth.
For our testing, we set all quality details to High and forced 8x Anisotropic Filtering in the driver menu as there is currently no support for it in game. We tested at 1280x1024, using 0x, 2x and 4x Anti Aliasing, 1680x1050 using 0x and 4x Anti Aliasing and 1920x1200 using 0x and 2xAA. By extensively testing using Anti Aliasing in very high resolutions, we'll be pushing even the bleeding edge hardware on test to the limit.
Pre-OC Nvidia GeForce GTX 280 and 260 Crysis DX9 Pre-OC Nvidia GeForce GTX 280 and 260 Crysis DX9
Crysis
1280x1024, 0xAA, 8xAF, DX9, High Detail
  • Asus GeForce GTX 280 TOP
  • BFG GeForce GTX 280 OCX
  • Nvidia GeForce GTX 280
  • Nvidia Geforce 9800 GX2
  • Zotac Nvidia GTX 260 AMP!
  • ATI Radeon HD 4870
  • Nvidia GeForce GTX 260
  • ATI Radeon HD 3870 X2
  • Nvidia GeForce 9800 GTX+
  • ATI Radeon HD 4850
    • 60.9
    • 41.0
    • 60.5
    • 40.0
    • 54.6
    • 36.0
    • 54.5
    • 32.0
    • 49.9
    • 33.0
    • 46.7
    • 26.0
    • 45.0
    • 29.0
    • 44.0
    • 24.0
    • 40.0
    • 26.0
    • 36.9
    • 22.0
20
30
40
50
60
Frames Per Second
  • Average
  • Minimum
Crysis
1280x1024, 2xAA, 8xAF, DX9, High Detail
    • 55.5
    • 37.0
    • 55.2
    • 37.0
    • 50.0
    • 33.0
    • 48.8
    • 29.0
    • 45.3
    • 30.0
    • 41.1
    • 27.0
    • 39.0
    • 22.0
    • 33.8
    • 21.0
    • 33.6
    • 19.0
    • 29.8
    • 19.0
20
30
40
50
60
Frames Per Second
  • Average
  • Minimum
Crysis
1280x1024, 4xAA, 8xAF, DX9, High Detail
  • Asus GeForce 9800 GX2 TOP
    • 52.5
    • 35.0
    • 52.0
    • 35.0
    • 47.3
    • 32.0
    • 43.0
    • 28.0
    • 42.5
    • 25.0
    • 41.4
    • 25.0
    • 38.8
    • 26.0
    • 37.8
    • 21.0
    • 29.6
    • 14.0
    • 29.1
    • 18.0
    • 28.5
    • 17.0
20
30
40
50
Frames Per Second
  • Average
  • Minimum
Crysis
1680x1050, 0xAA, 8xAF, DX9, High Detail
  • Zotac GeForce GTX 260 AMP!
    • 48.7
    • 35.0
    • 48.5
    • 34.0
    • 45.6
    • 27.0
    • 43.8
    • 31.0
    • 39.9
    • 28.0
    • 37.4
    • 22.0
    • 36.0
    • 24.0
    • 32.3
    • 21.0
    • 31.3
    • 19.0
    • 29.6
    • 19.0
20
30
40
50
Frames Per Second
  • Average
  • Minimum
Crysis
1680x1050, 4xAA, 8xAF, DX9, High Detail
    • 42.0
    • 30.0
    • 41.8
    • 30.0
    • 38.0
    • 27.0
    • 31.1
    • 24.0
    • 30.9
    • 22.0
    • 29.4
    • 16.0
    • 24.6
    • 11.0
    • 22.2
    • 14.0
    • 20.6
    • 11.0
    • 19.1
    • 10.0
20
30
40
Frames Per Second
  • Average
  • Minimum
Crysis
1920x1200, 0xAA, 8xAF, DX9, High Detail
    • 39.6
    • 28.0
    • 39.4
    • 28.0
    • 35.7
    • 25.0
    • 32.2
    • 22.0
    • 32.1
    • 27.0
    • 30.1
    • 17.0
    • 29.0
    • 19.0
    • 25.9
    • 16.0
    • 25.1
    • 12.0
    • 23.7
    • 15.0
20
30
40
Frames Per Second
  • Average
  • Minimum
Crysis
1920x1200, 2xAA, 8xAF, DX9, High Detail
    • 35.9
    • 25.0
    • 35.7
    • 25.0
    • 32.5
    • 23.0
    • 30.9
    • 20.0
    • 29.0
    • 13.0
    • 26.3
    • 18.0
    • 24.0
    • 15.0
    • 18.4
    • 12.0
    • 18.3
    • 9.0
    • 18.2
    • 9.0
20
30
40
Frames Per Second
  • Average
  • Minimum
In DirectX 9.0c Crysis the results are much the same, with the overclocked cards displaying around a ten percent advantage over the stock versions. The GeForce cards had always held the advantage in DX9 Crysis, but once overclocked the GeForceGTX 280 really stretches its performance lead over the Radeon HD 4870 to well over ten frames a second in some circumstances!
Where the stock clocked GeForce GTX 260 flirted around the Radeon HD 4870, the Zotac GeForce GTX 260 AMP! is just the ticket to consistently see it perform consistently better. Obviously you can overclock the Radeon too, and we will get to that soon, but it already runs extremely hot without it.
